Trowel Grade Leveler Or Self Leveling Compound - Flooring - DIY Chatroom Home Improvement Forum
Old 03-24-2014, 09:38 PM   #1
Rewards Points: 71
trowel grade leveler or self leveling compound
i am taking on the task of tiling a 100sqft room in our house. just tore out the carpet, carpet strips and base boards. i have a 4' level and with that alone i could tell that there is some minor low spots on the floor. so i guess i will need to get the surface nice and flat with some compound.
ive been reading up on the process and stuff like LevelQuik seems to be basically poor on the low spot and let it do its job (with a little coaxing and feathering of course). also, there is no need to pour the level over the ENTIRE floor, just the low spots to build it up flat, right?
ive also been reading on Sakrete's Trowel Grade leveler. Its more putty like and i was thinking of applying it to the low spots and then dragging an 8' aluminum screed to smooth/flatten it out.
any thoughts?
joshik is offline   Reply With Quote
Old 03-24-2014, 10:31 PM   #2
Retired Moderator
Rewards Points: 7,174
that is a very simplified plan---but a good one---the self leveling compounds require a primer---usually---and need a fast hand because it sets up quickly--
Feather Finish is my first choice for a trowel-able patching compound--Ardex makes it--Home Depot carries Ardex products.
joshik (03-24-2014)
Old 03-24-2014, 11:51 PM   #3
Rewards Points: 71
cool. yeh, the SLC 15min set time scares me. i saw there is a 30min set SLC as well but I'll check out the Ardex stuff! I was also thinking of going to shortcut route and just use thinset but prob wont do that...
Old 03-25-2014, 06:40 AM   #4
Retired Moderator
Thinset shrinks when it sets----don't attempt to level with it---
rossfingal (03-25-2014)
How to repair a cracked driveway or walkway [email protected] How To Guides 8 06-15-2015 04:59 AM
Self Leveling Q Polapea Flooring 10 04-03-2012 09:21 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
