Trouble Sanding Hardwood Stairs - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 11-09-2017, 05:24 PM   #1
Rewards Points: 2
trouble sanding hardwood stairs
I removed carpeting from my stairs and I want to paint the risers and sand and poly the stairs and bannisters.
The poly is a clear coat (im not staining- keeping the natural wood color) oil based product.
I was able to sand the banisters down using 60,100 and 120 grit paper with a combination of an orbital hand sander, a palm sander and an oscillating tool with attachment heads and sand paper.
However when I tried to sand the stairs themselves it doesnt feel like I am accomplishing much.. except making it a little cleaner
I am wondering what type of wood this is and maybe I need to go to a coarser grit?
The stairs are not in too bad of shape and they may have been poly'ed once before (probably 30+ years ago).
I dont know if they just need a good cleaning and sanding with less coarse paper before applying the oil based clear poly..
Any suggestions?
BTW.. the stuff between the edge of the steps and the risers are plastic wood.. Most of the steps had noticeable gaps in them so i spread this stuff in there like you would spread caulk..Filled in some minor chips too..Hoping it will absorb the stain and not be so noticable..
First picture is steps I have sanded with 60 grit
Second pic is unsanded and messy plastic wood spread across (sorry it came out sideways)
trouble sanding hardwood stairs-steps1.jpg   trouble sanding hardwood stairs-steps2.jpg
Steve007 is offline   Reply With Quote
Old 11-10-2017, 05:38 AM   #2
retired painter
Rewards Points: 1,838
Re: trouble sanding hardwood stairs
Looks like oak treads to me. The plastic filler may be problematic, generally they don't take stain well. Treads are basically done the same way as flooring, start out with a coarse grit and finish with a finer grit. Since it's next to impossible to sand the corners you'd use a sharp scraper there to remove the old finish there.
Dave Sal likes this.
mark sr is offline   Reply With Quote
Old 11-13-2017, 03:12 PM   #3
Rewards Points: 368
I would suggest renting a floor edger it will make for much easier work on the stairs. Most tool rental shops have them available, including Home Depot. Hope this helps.
Awoodfloorguy is offline   Reply With Quote
Refinishing Very Old Hardwood Stairs mikemark8808 Painting 5 09-29-2015 09:10 PM
New Hardwood Stairs smrf1080 Carpentry 21 07-22-2012 10:35 PM
Ideas for refinishing hardwood stairs?? RinSF Flooring 10 06-01-2010 03:25 AM
Hardwood Stairs warnerww Flooring 9 04-24-2010 07:56 AM
Hardwood & Stairs budcam Flooring 4 09-15-2009 11:12 PM
