Trick Question - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2015, 07:10 AM   #1
Rewards Points: 7,194
Trick Question
It looks as if water soaked up through my concrete step, but not all of the surface indicates that. Why?
Old 12-16-2015, 07:57 PM   #2
Rewards Points: 2,186
no pic for me.
Fix'n it is offline   Reply With Quote
Old 12-16-2015, 10:20 PM   #3
JUSTA MEMBER
Rewards Points: 4,282
Yep: your post is cursed with a black box with a big X in it.
Concrete will wick up only as high as the available water that is available in your ground.
You might get only a bit of saturated ground , or you may have a lot. Depending on seasonal changes.
ED
de-nagorg is offline   Reply With Quote
Old 12-16-2015, 11:17 PM   #4
Pic from personal folder and posted through normal site procedures. Shows for me. Says it uploaded.
Old 12-17-2015, 10:13 AM   #5
JUSTA MEMBER
Now I get a photo.
Was I ever mistaken in my first post. YES
How old is that step, if it is still curing I would not worry too much.
But if it is at least 6 months old you might be concerned.
ED
Old 12-17-2015, 11:29 AM   #6
I poured the step 31 years ago. It's on sand that's dry as a bone.
Old 12-17-2015, 12:19 PM   #7
JUSTA MEMBER
31 years.
it's cured.
Do you use a de-icer in the winter, that can discolor concrete?
Maybe some kind of cleaner came from inside the building.
ED
Old 12-17-2015, 12:22 PM   #8
Originally Posted by de-nagorg View Post
31 years.
it's cured.
ED
No and no to de-icer or cleaner.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
de-nagorg (12-17-2015)
Old 12-17-2015, 12:24 PM   #9
No wet looking area today. It all looks dry.
Old 12-17-2015, 01:18 PM   #10
No dry pics now. It's snowing on it.
Old 12-17-2015, 01:54 PM   #11
Rewards Points: 8,907
Could it be a small growth of concrete mold that shows when dampened or the light is just right?
A 10% chlorine bleach solution applied in warm weather will determine that. Rinse well.
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is offline   Reply With Quote
Old 12-17-2015, 05:30 PM   #12
Rewards Points: 2,906
If it were moisture coming up through the concrete, it wouldn't dry up that quickly.
I think what you saw in that picture you posted was condensation forming on the SURFACE of the concrete. You have to remember concrete is heavy as sin. It cools down at night, and it takes a good few hours for it's surface to warm up during the day. During that time, as the air temperature (and humidity) rises, condensation will form on the still cold concrete. That makes the surface of the concrete wet, and it's easy to mistake that for moisture rising up through the concrete.
Also, if you live where temperatures drop below freezing in winter, then the water expanding as it freezes inside the concrete will cause something called "spalling" where the surface of the concrete breaks off in chips. Condensation on the surface of the concrete won't cause spalling because the moisture isn't deep enough in the concrete.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 12-17-2015, 06:02 PM   #13
Nestor gets the A+ on the test question and has bragging rights as long as he wants. Good job.
The dry area in the upper right was 64F ( 17.7c ), damp area was 61F ( 16.1c ) and the dew point temperature was 62F ( 16.6c).
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
