Transition From Hardwood To Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2014, 04:41 PM   #1
westleykarcher's Avatar
Rewards Points: 71
Transition from hardwood to tile
When I purchased my house it was in need of some work. The previous owners had a good idea on the transition but I made it reality. I had to remove the damaged tiles. Found some extra tiles stashed in the garage. Bought a $20 tile cutter from action pawn and cut the tiles to size. Used some chippings from the demolished tiles and used enamel paint to darken the colored tiles. Grouted it all in. Not a bad idea on a wood to tile transition.
Transition from hardwood to tile-securedownload-3.jpeg   Transition from hardwood to tile-securedownload-4.jpeg
westleykarcher is offline   Reply With Quote
The Following User Says Thank You to westleykarcher For This Useful Post:
oh'mike (04-14-2014)
Old 04-14-2014, 04:51 PM   #2
Rewards Points: 19,142
Got a picture?
How do you figure painted tiles is going to hold up to foot traffic.
Old 04-14-2014, 04:53 PM   #3
Rewards Points: 71
It's been a year and it's held up nicely. You could always use epoxy paint, but enamel worked very well.
Hardwood higher than Tile deaner00 Flooring 6 05-18-2018 12:33 PM
Tile transition to hardwood floor (1" lower) gambit Flooring 2 04-02-2012 03:20 PM
Transition from hardwood to tile 1" higher acerunner Flooring 3 03-01-2011 09:44 PM
Laying tile over hardwood stairs steps Flt_Simulation Flooring 12 01-06-2011 08:33 PM
installing hardwood against tile doorway tim7488 Flooring 1 03-30-2010 06:13 AM
