Too Thick For Thinset - Flooring - DIY Chatroom Home Improvement Forum
Old 08-03-2014, 12:06 PM   #1
Rewards Points: 984
Too Thick for Thinset
I have to put down about 12 tiles that will match the tiles in the existing area. Problem is that whoever laid the original tile must have put a thick base down because when I put the thinset down the tile was not level and needed more height. I do remember in the past when I put a thick layer of thinset down it never really dried. Is there anything else I can put down as thick base for the tile? Thanks?
Mstrlucky74 is offline   Reply With Quote
Old 08-03-2014, 04:43 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No. Use thinset. May have to mix it a little tighter.
What do you mean "it never really dried"?
XXX
Old 08-03-2014, 05:22 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
Sounds like you may have a mud bed under the tiles. How thick is the base, what's under it and what's the difference in thickness from the rest? Got pics?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 08-03-2014, 08:17 PM   #4
Rewards Points: 984
I bought the premixed.
Old 08-03-2014, 08:18 PM   #5
Rewards Points: 984
Jaz
Not sure what's under it. I'm about 1/2" short when thinset is applied
Old 08-03-2014, 10:41 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That's is one of the worst products to ever hit the market, you are correct, when applied in thick fashion it will never dry/cure. Never use a pre-mixed thinset for anything other than installing tile on drywall totally away from a wet area and never use it to fill anything. The pre-mixed thinset is crap and has its limits.
XXX
Old 08-03-2014, 10:44 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not following this either. How could there be a 1/2" shortage if all you did was remove some tile and you are now trying to simply replace it?
XXX
Old 08-03-2014, 11:08 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 780
.....and why not? Let's start with simple. Is it concrete or wooden floor?
I'm pretty sure you have a layer of mud under there. The pre-mixed stuff is not thinset and as Bud said it's junk for floors and wet areas. But please answer the q's.
Jaz
Old 08-04-2014, 03:53 AM   #9
Pro
Rewards Points: 91
What do you mean you're not sure what's under it. What do you see there?
As everyone else has pointed out, the premixed isn't useful. Basically it's glue, and it won't dry out. To build up you will need either to add a layer with concrete board or the like, or build up with a mortar that will allow you to build a medium bed. A problem that you're going to have is that the underlayment beneath the new section will be different from that below the old, and the border will want to crack.
The more questions you answer, the more helpful will be the answers.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Grout - How thick is too thick, and how to build up a low area? imautoparts Tiling, ceramics, marble 5 12-16-2012 04:50 PM
Pricing a 1 layer tear off of a flat roof. Then installing 1-1/2 thick insulation and 60m. thick EPDM. I need a price per square on labor and materials. Thank you. Tim. pete1700 Roofing/Siding 11 07-19-2011 09:31 AM
Paint that applies thick and dries rubbery? konsole Painting 2 06-01-2011 02:24 PM
How thick is too thick for mortar bed in block foundation wall Clutchcargo Building & Construction 6 05-27-2011 06:32 AM
Does 1.5" thick drywall really exist? mikheil Drywall & Plaster 19 11-12-2010 07:11 AM
