Tmolding At Door Frame - Flooring - DIY Chatroom Home Improvement Forum
Old 01-28-2015, 11:55 AM   #1
Rewards Points: 28
Tmolding at door frame
Hello I already have the flooring in and the door frame was cut underneath for the tile and wood. Now I have 4 door frames I need to install the t molding on. Do I need to undercut the door frame or just just the wood that stops the door? If I do need to cut under the door frame can I get by with a dremel or do I need something else, and preferably multi functional.
FastEddie26 is offline   Reply With Quote
Old 01-28-2015, 11:07 PM   #2
Rewards Points: 5,012
Just cut the stops and install the T flush with frame then caulk.
ron45 is offline   Reply With Quote
