Tiling Bathroom Floor.... - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-23-2011, 10:37 AM   #31
Tile with Style
BlueStoneFloors's Avatar
Looks good, Tom. More screws is always better, especially around your toilet and down the main traffic walkway. You can still put more in now, mortar won't be dry for a while. Full tiles against the tub looks the best with that type of layout. Go to Harbor Freight if you have one and buy the multitool for undercutting your door casings. It's like $30 and you will love that tool for so many jobs. take a tile and 2 pieces of cardboard(that simulates the increase in flooring height with mortar) and use that as your cutting guide. As close to full and half tiles in the doorway as you can calculate, but don't cut it too close. I'd use a 3/8" trowel for that tile...More consistent than 1/2", more adjustment than 1/4"...Got your msg I'll reply when I get a few minutes, best of luck buddy...
Hell is 8 months of nothing but slate work...
BlueStoneFloors is offline   Reply With Quote
Old 08-23-2011, 02:44 PM   #32
It's been almost 48hrs since installing the durock, can i still put more screws or would it even help at this point?? They are mostly 8'' apart but some are 6-7''.
tomknox is offline   Reply With Quote
Old 08-23-2011, 04:59 PM   #33
Tile with Style
ehh... I'm really not sure I've never waited that long. Ask Bud or Jazman
Old 08-23-2011, 06:16 PM   #34
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I've never waited that long either. Nothing to lose by experimenting a little since that seems to be the policy anyway.
I would try driving a few more screws. If they cause little upheavals then don't do any more.
XXX
Old 08-23-2011, 06:54 PM   #35
Thanks bud, i will give it a try and see what happens. I will let you know how it goes! I thought maybe i should'nt, the floor is sound and does'nt creak or crack in anyway. My pop's did the muddin, but he's been laying brick for 30 years!
Old 08-23-2011, 07:03 PM   #36
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I understand but over time the thinset will likely release from the substrate and...
Oh Wait, I think I already said that.
XXX
Old 08-23-2011, 09:09 PM   #37
Bud yes you did say that, you probably feel like a broken record sometime's!!
*UPDATE*
The screw's went in fine, i hope that it has no repercution's! After that i mixed up just a little mud to get by tail feather's wet on this tiling thing. I had a fun time doing it and can't wait to do more!! Here's where i'm at now...
Old 08-23-2011, 09:24 PM   #38
Retired Moderator
Rewards Points: 7,174
Why did you leave the toilet tile out? It's not good to leave tiles out--very hard to get them in afterwords.
Typically the full cuts at the tub are first --then work your way over to the cut ones---that way if any adjustments need to be done it's on the cuts and not the fulls.---Mike---
Old 08-23-2011, 09:41 PM   #39
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would have started at the tub and worked my way to that wall in the above photo. You may (now) find yourself shaving tiles at the tub and that isn't always easy to do.
XXX
Old 08-23-2011, 11:23 PM   #40
I've got snip's and a HD straight 20.00 dollar cutter. I figure that i would have to get lowe's to cut it or buy a bit for my dremell....
I laid the tile out dry and marked w/pencil, i scraped the extra mud out around and checked with another dry tile for a quick measure and it seemed fine. I figure that i could hide any difference w/the toilet, and make it toward's the wall side/corner if there was any major difference's?
I agree 100% and i should have done that, the only thing that held me back was the vent hole for the A/C. I cant make those cut's either, so i did'nt start there. I should have though, if i planned good enough then i think it should be fine. Yall guy's pray for me!!
I just learned how to quote so i did it again, hope it doesn't make me look like a
Old 08-23-2011, 11:36 PM   #41
Retired Moderator
You would benefit from owning a 4 1/2" angle grinder with a diamond blade---Handy for the few cuts that you have there.
Old 08-24-2011, 08:13 AM   #42
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you "planned good enough" you would be starting at the correct location and cutting tiles as you go.
XXX
Old 08-24-2011, 01:08 PM   #43
Fair statement, i did however check again since you guy's had me worried. Whata ya know, it's fine! Just goes to show that there's more than one way to skin a cat bud.
Old 08-24-2011, 03:20 PM   #44
Tile with Style
Well Tom, Bud is correct it's much easier to install tiles as you go. Not so much an issue with toilets and vents, but when you get to those meddlesome door casing you won't be able to slide tile underneath them if the tile next to it is installed and dry. From a pro's perspective, it's just good policy to not leave tiles open in the middle of a pattern. How's that Castlevetro tile to work with? They make a good product, and actually bake it all the way through! If I was you and planned on possibly doing tile again in another area, I would look on Craigslist for used wetsaws. I'm guessing $100 u could get a decent MK or $200 for a Dewalt chop arm wetsaw. Running cuts to the tile store is ridiculous, bro...Let me know if you hit any snags
Brian
Old 08-24-2011, 03:43 PM   #45
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you don't heed another suggestion, please listen to the one above. Brian is 100% correct.
XXX
Carpet in the basement Packer Backer Flooring 17 11-30-2018 03:10 AM
Tiling a bathroom floor and installing under floor heating tlovesb Flooring 6 02-04-2011 07:01 AM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
