Tile Transition Strip Damaged - Flooring - DIY Chatroom Home Improvement Forum
Old Yesterday, 09:13 PM   #1
Rewards Points: 26
Tile transition strip damaged
Hi,
I have a transaction strip between ceramic tile and wood floor that has a bit missing, knocked out. It looks like the strip goes under the edge of the tile. Wondering if it can be replaced without taking up the tiles at the edge. Any suggestions on a fix?
Nick1 is offline   Reply With Quote
Old Today, 12:02 AM   #2
Rewards Points: 908
Re: Tile transition strip damaged
I would break the rest of it off and mill a thin piece of oak with tapers on both sides. Then I would stain it to match the floor and install it so it overlaps the tile a little. If the floors are a bit uneven, rabbit it so it fits flat.
You might find a ready made transition strip in the flooring aisle at a big box.
That piece likely has an inch wide leg under the tile.
Old Thomas is offline   Reply With Quote
Old Today, 12:10 AM   #3
Mystriss's Avatar
Rewards Points: 4,730
If I had to guess, I'd say the wood that's running the other direction from the rest is the transition strip, but it's not installed right from the looks of it. The wood bit should go up and over the tile edge, it shouldn't be a hard 90* like that (or at least that's how it looks in the picture.)
If it were my floor I'd try to pull up the strip of wood at the nearest "edge" (against a wall/door frame usually) and take it in to find a reducer transition piece that matches the color. Looks like a light oak - should be easy enough to find a match - you just have to find one that's a bit wider to go over the tiles.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Old Today, 07:45 AM   #4
Rewards Points: 9,298
The transition strip is likely set in the mortar under the tile. You can search "schluter floor profiles" if you want to see examples of how it is commonly done. Except looks like they cheaped out and used plastic.
An oscillating saw will make quick work of removing what is left over.
Is the tile higher than the hardwood ?
Home Depot or Lowes will have wood transition strips. Your hardwood looks like oak, so that is very common and easy to match. Might have to modify the transition strip.
SPS-1 is online now   Reply With Quote
Old Today, 07:52 AM   #5
retired framer
Rewards Points: 5,660
If you can cut it off below the floor level and then just fill in with grout.
Do not use flat bottom gables with scissor trusses.
Old Today, 08:18 AM   #6
The hardwood moves with changes in humidity. Caulk would be a better choice than grout.
