Tile On Subfloor Or On Slab? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By EdBoston
Old 04-11-2018, 07:12 PM   #1
Rewards Points: 14
Tile on subfloor or on slab?
Looking to replace basement flooring that is currently carpeted (yuck), with plywood subfloor over the grey dimpled moisture barrier underlayment. I’m planning to lay natural stone tiles. Should I demo out the subfloor and work from the slab, or just put a CBU layer on the plywood and tile on that?
EdBoston is offline   Reply With Quote
Old 04-11-2018, 07:23 PM   #2
retired framer
Rewards Points: 20,208
Re: Tile on subfloor or on slab?
I would not leave anything that mold could live on under tile. Just a minor flood like water tank or washer from anywhere in the house would cause huge problems. You can't just remove it like you could the carpet to let it dry out.
EdBoston likes this.
Old 04-12-2018, 04:42 AM   #3
Rewards Points: 14
Yeah, I was thinking more about the stability/durability of the installation but that is a good point too. We have never had water issues in the basement but it only takes one time to ruin it.
Nealtw likes this.
Interior Drain Tile, slab issues cjohnson9405 General DIY Discussions 9 03-16-2017 11:40 AM
Lowering basement slab and installing drain tile diybrad Concrete, Stone & Masonry 0 04-26-2012 09:36 AM
Porcelain tile over particle board over concrete slab? roughtrader Flooring 9 04-16-2012 11:24 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Old tile over Slab fishgirl Flooring 4 07-05-2010 01:58 PM
