Thinset - Flooring - DIY Chatroom Home Improvement Forum
Old 05-13-2014, 02:36 PM   #1
Rewards Points: 85
thinset
I have a 4' by 5' area at the bottom of my stairs going to the basement that I want to tile with some ceramic tile. Problem is I have two bags of thinset, neither bag is enough to do the whole job but both together would be enough. One is a bag of Mapei floor tile thinset, the other bag is C-Cure Floor Mix 900, I can't see any problem in mixing the two together then mixing with the water to set the tile. It's a long haul to the nearest Lowes and I am just trying to save a trip.
boilermaker27 is offline   Reply With Quote
Old 05-13-2014, 02:59 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 754
I've mixed various thin sets in the past and certainly see no problem here. The only question is; when was the material made, when did you buy it, when did you open the bags, and where has it been stored? Look for dates and codes on the bags.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 05-13-2014, 03:01 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
This is probably do-able but I wouldn't mix the two products together. Use them separately as they were intended. Dry-mixing the powders first could wreck the chemistry and render the entire quantity useless.
Keep in mind however that these products have a shelf-life and depending on how long you have had them and how they were stored they may be useless anyway. Thinset is inexpensive. If the products on-hand have been around more than six months I would trash them and buy new.
Old 05-13-2014, 03:19 PM   #4
Rewards Points: 85
Both bags of thinset are old, have no idea how old, but at least a few years. Both bags were rolled and sealed with duck tape. The powder is fine, dry, no lumps. Just wondering what can go bad? So, if I make another trip to Lowes or Home Depot what do you recommend?
Old 05-13-2014, 03:49 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow well.......don't kid yourself! The powder can "look" fine but can have already gone-off due to atmospheric conditions over time. It isn't worth it! Throw that stuff away and buy new. Both home centers carry good mainstream products.
There doesn't have to be any lumps for the product to be bad.
Old 05-13-2014, 04:07 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 754
Absolutely, take it to the curb on garbage day.
As Bud said, it doesn't have to be in lumps to be bad. Portland products have a shelf life of a year or so IF unopened and stored in a conditioned room off the floor if a slab. Once opened it's ok for a short time. How long? Who knows?
The bags have dates on them and sometimes they're half gone when you take it home. If Lowes is a long ride, try a friendly local hardware store, there's gotta be one nearby, no?
Jaz
Old 05-13-2014, 04:23 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ace Hardware carries a limited supply of thinset in this area.
Hi Jaz !
Old 05-13-2014, 04:38 PM   #8
Rewards Points: 85
just got back from Lowes with a new bag of Thinset, thanks for the help.
The Following User Says Thank You to boilermaker27 For This Useful Post:
Bud Cline (05-13-2014)
Old 05-13-2014, 05:07 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wise decision grasshopper.
tile with dried thinset tdpdiy Tiling, ceramics, marble 4 05-18-2014 08:54 PM
using recently mixed thinset with newly mixed thinset DiyCR fan Flooring 6 03-19-2013 09:19 AM
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-04-2012 12:00 AM
questions about thinset ponch37300 Flooring 16 03-16-2011 12:45 PM
Fortified Thinset poolecw Flooring 4 10-31-2008 08:06 AM
