Is There A Way To Repair This Damage To The Stair Tread? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-22-2015, 09:31 PM   #1
Rewards Points: 43
Is there a way to repair this damage to the stair tread?
This damage was caused when trying to rip out carpet. Can this be repaired? My guess is that buying a new stair tread is the only option. Are stair treads sold at Lowes or Home depot?
bugmenot is offline   Reply With Quote
Old 11-22-2015, 10:02 PM   #2
JUSTA MEMBER
Rewards Points: 14
That looks like a laminate separation to me. It can be glued back down, with the proper clamping force and a caul, but it probably wont stay.
Yes the treads are sold at the BOX stores.
And that is what I would do : replace it.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
bugmenot (11-22-2015)
Old 11-22-2015, 10:33 PM   #3
Rewards Points: 43
Is there a way sanding and wood filler would do the trick? Any ideas?
Old 11-22-2015, 11:11 PM   #4
JUSTA MEMBER
Rewards Points: 14
If that is laminate , there is not much there to sand before you have a hole too big for filler.
Filler might take care of the small ones, but that big gouge will be tough to blend back to a resemblance of it's self.
ED
Old 11-22-2015, 11:26 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 68
If you can find some wood that will match, you can cut a strip all the way across about 5/16 inch deep with a router and guide then glue the strip in, sand and stain to match. Sorta like doing an inlay. It looks like the tread is joined there at the tear anyway.
You would need to do a little chisel work at the ends, but it is doable, depending on your wood working skills.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
gregzoll (11-23-2015)
Old 11-23-2015, 07:46 AM   #6
Rewards Points: 18,052
If the plan is to stain and seal any repairs, fillers used is going to stick out.
Replacing stair tread on closed stringer stairs... J187 Carpentry 11 01-16-2017 07:24 PM
TREX decking for stair tread question ryan5068 Landscaping & Lawn Care 5 06-18-2013 09:40 AM
Deck stair tread and riser aesthetics jenmarie Carpentry 4 07-17-2012 05:40 PM
Putty or Spackle for stair rail and latex chip/peel repair. RickDel Painting 3 05-14-2012 11:12 PM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
