Is There A Flexible Grout For Porcelain Flooring - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2017, 12:27 PM   #16
Rewards Points: 4
Re: Is There a Flexible Grout for Porcelain Flooring
I have used the Schluter®-DITRA heat floor system. It is orange and looks like lego blocks. You can purchase to use with or without infloor heating and doesn't cause extra work. I tile and my husband does the cutting. I used in in my master bathroom and have not had any issues. I will use the same underlay in my last bathroom reno in the house as well because I do not have 1" understructure. Amount of subfloor is dependent on how wide joists are set apart. etc. It made adding heating cable so easy as I just pushed them into the spaces between the pegs. If you didn't run it right you just pull it up and do it again. Easy enough for a girl to do. Lay a skim of cement, push the mat into it. Push the cables in then tile. Added 1/4" to overall height.
Moira Wilkinson is offline   Reply With Quote
Old 01-13-2017, 12:32 PM   #17
Rewards Points: 4
Can I mix my own? With clear caulking? I will let you know how it works. Thanks.
Old 01-13-2017, 12:43 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 750
Hi Moira,
You can't do that. What did you mean to say and use?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
Flexible Vinyl Flooring moneymgmt Flooring 6 03-13-2008 10:47 PM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Cracking floor grout - Ceramic tile DeepDish Flooring 9 03-03-2007 07:49 PM
