Terminology / Glossary Of Vinyl Flooring - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By justinrobinson
  • 1 Post By Old Thomas
Old 04-08-2020, 01:57 PM   #1
Rewards Points: 46
Terminology / Glossary of Vinyl Flooring
Important terminology that describes Vinyl Flooring and related elements in the various regions of the world.
Subfloor = the material used as the base product of the floor construction. This could be concrete slab or a wood panel product nailed to floor joists
Substrate = the surface you are installing new flooring over
Underlayment = Underlay or underlayment generally refers to a thin layer of cushioning made of materials such as sponge rubber, foam, felt, crumb rubber, or recycled plastic; this material is laid beneath carpeting to provide comfort underfoot, to reduce wear on the carpet, and to provide insulation against sound, moisture, and heat.
Flash coving = vinyl ran up the wall to an accepted molding in lieu of wooden or rubber baseboard.
Floor patch = material, either portland or gypsum based, used to fill and smooth rough areas, voids, and joints between underlayment panels.
Flash time = the time an adhesive should be left uncovered after spreading to let moisture and or gasses to evaporate before covering with vinyl. usually listed on adhesive containers.
glue trowel = a tool used to spread adhesive and to measure the proper amount of glue being spread on the floor.
seam sealer = a product sold by the flooring manufacturer to, well, seal the seams to prevent dirt collection at the seam area and to prevent curling.
roller = a device to roll the floor to evacuate any air or gasses that cause bubbles. usually 75# with three "wheels "
double cut = a common method of cutting a seam by cutting through both fields and filling pieces at a pattern line at the same time. commonly used for inserting patches.
butt seaming = cutting seam edges separately before assembly and putting them together.
pattern scribing = making a pattern of the floor with kraft paper or felt paper as a template and then cutting the vinyl to shape in a more convenient area.
restrictive molding = a molding used to prevent curling of the edges of a vinyl floor.
undercutting = making a saw cut generally where a molding is unacceptable (like a door casing) under which the vinyl is inserted.
Full spread = covering the entire floor with adhesive (most vinyl floors require full spread)
perimeter glue = some styles of vinyl flooring only require a narrow band of adhesive around the edges and seams.
vinyl tile= Looks like stone or ceramic tile, looks realistic.
vinyl plank= Looks like wood, looks stunning
Please do suggest if I miss any term
udraft likes this.
justinrobinson is offline   Reply With Quote
Old 04-08-2020, 03:07 PM   #2
Rewards Points: 4,564
Re: Terminology / Glossary of Vinyl Flooring
VCT=vinyl composition tile
Binding=strip used to secure an edge
Transition strip=piece used to join finished floors at slightly different elevations
udraft likes this.
Old Thomas is offline   Reply With Quote
Old 04-08-2020, 04:27 PM   #3
Hammered Thumb
Rewards Points: 2,596
No need to copy and paste verbage you got from another website. Especially a non-professional website.
3onthetree is offline   Reply With Quote
Tags
flooring , plank , tile , underlayment , vinyl flooring
