Template For Decreasing Radius Trimout - Flooring - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 08:44 PM   #1
Template for decreasing radius trimout
I will be attempting my first hardwood floor install soon and have some questions for the pros. Lets start with the subfloor. I have a 20x30 carpeted great room with 23/32 T&G osb with a plywood overlay. Not sure of the overlay thicknees just yet. 2x10 joists 16oc. The floor I have ordered is 3/4 x 3 1/4 prefinished red oak, rift and quartered.
Will I need an expansion joint due to the room size or does rift and quartered not require it ?
I have a tiled entry at the front door and at the sliders in the rear. They are trimmed with a radius thats not 100% perfect but the line where tile meets carpet looks good. I would like to butt my new hardwood up to the tile and trim out with a custom made quarter round, hoping I can make it thin enough to make the curve.
[/IMG]
Tell me if I am on the right track here. I plan to lay a sheet of 1/4 luan over the tile and trim the radius with my router. I can then layout the planks under the luan and scribe the radius for the proper cuts to the planks.
Again, another concern is expansion. Do yo think there will be a problem butting flush with the tile?
Lets hope the pic was inserted correctly. Thanks.
roblectric is offline   Reply With Quote
Old 10-17-2011, 08:44 PM   #2
http://i1093.photobucket.com/albums/...c/IMG_0183.jpg
My planks will be running parallel with the door.
Joists perpendicular to door.
Old 10-18-2011, 12:03 AM   #3
Rewards Points: 200
Flexitions - Flexible Transition Moldings - Home
Floor Doc is offline   Reply With Quote
Old 10-18-2011, 06:34 AM   #4
Originally Posted by Floor Doc View Post
They are too proud of that stuff. $155 for a seven foot piece is just wrong.
Old 10-20-2011, 05:00 PM   #5
Can anyone chime in about the expansion joint?
Old 11-03-2011, 04:59 PM   #6
I see JazMan responded to a post with a situation similar to mine. He suggested using sanded grout for tile to hardwood transitions. Thanks JazMan, this might work for my problem. If my hardwood will end up 3/8nch higher than the tile, will I still need some sort of custom trim to cover the exposed tongue and groove?
Old 11-03-2011, 05:07 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can't disagree with you there. That is one of those take it or leave deals.
If you make your cuts properly the caulk should work for you.
template for drawers xd40hg Carpentry 7 04-13-2011 09:56 PM
Router Template WirelessG Carpentry 14 03-28-2011 09:52 AM
stair template HELP ME PLEASE mauddee Carpentry 10 02-13-2010 04:36 PM
Arched beam radius tee2 Building & Construction 3 07-16-2008 04:47 PM
Is There a Framing Template? snapshots Building & Construction 13 08-25-2007 11:44 AM
