Suggestion For The Floor Work!! - Flooring - DIY Chatroom Home Improvement Forum
Old 06-19-2015, 01:24 AM   #1
Rewards Points: 6
Suggestion for the floor work!!
We have recently moved to Ottawa. The garage floor in the house is completely damaged and we are planning to do the flooring work. There are pits and scratches on the garage floor. We are thinking to do epoxy coating for the floor. What is your opinion on that? Any suggestions are gladly accepted.
lmore is offline   Reply With Quote
Old 06-19-2015, 06:06 AM   #2
Retired Moderator
Rewards Points: 7,174
If the concrete is falling apart--the epoxy may stick to the loose flakes and then pop loose----
Post a picture, if you have one, and you will get a better answer---
suggestion needed for a whole house water system kan Plumbing 2 03-30-2013 11:03 AM
Need color suggestion please! Mandyfin Interior Decorating 13 12-06-2012 06:59 AM
X10 or Insteon or Lutron ? Automation suggestion? 5taehoon Electrical 6 02-19-2011 01:42 AM
a good suggestion to be taken seriously Handy Vinny Site Help and Suggestions 4 09-13-2010 10:26 AM
Drainage issue and need suggestion on type of grass golfer2b Landscaping & Lawn Care 9 03-24-2008 07:38 PM
