Subfloor/underlayment Prep For Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 09-29-2014, 11:12 AM   #1
Rewards Points: 16
subfloor/underlayment prep for hardwood
Background: I am installing new hardwood over crawlspace area in Bay Area CA. In order to make the finish floor height match tile floor height in adjacent kitchen I am adding layer of 1/2" ply as underlayment on top of the 3/4" subfloor which I have already leveled. The hardwood instructions call for 15# felt paper vapor retarder which I am installing under the 1/2" ply.
Question: In understand that it is a good idea to use some sort of paper under the hardwood itself to minimize squeaks. Can I now use tar paper for that or would it be a problem to have the 1/2" ply sandwiched between two vapor retarders in which case I guess I would use red rosin paper? Also, if sandwich is OK, will the two layers provide me extra benefit or will it effectively reduce the total subfloor perm rating to a level that would actually cause me a problem? Note also that I said tar paper instead of #15 felt for right under the floor would there be a benefit to actually using the felt here as well instead of the thinner tar paper?
naulleau is offline   Reply With Quote
Old 09-30-2014, 02:51 PM   #2
Rewards Points: 12
construction paper
Naul,
I don't see any problem with using 2 layers of construction paper and you would get an extra benefit for the squeaks as you mention as well as an extra insulating layer, which would be a benefit given its over a crawl space. However, I can't speak to the perm rating issues at all…need some other opinions on that one.
diynot is offline   Reply With Quote
Old 09-30-2014, 05:23 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Does the crawl space have a vapor barrier?
Does the crawl space have cross-ventilation?
Do you use a dehumidifier?
XXX
Old 10-03-2014, 11:46 PM   #4
Rewards Points: 16
Has cross ventilation with smartVent system. Thinking of installing foam board insulation to bottom of subfloor between joists.
Old 10-04-2014, 11:30 AM   #5
Rewards Points: 377
You don't put tar paper inside the house. Tar off gasses VOC's.
Floors squeak not flooring.
You should investigate under the joists to eliminate squeaking buy adding some metal brackets or glue.
begal is offline   Reply With Quote
Old 10-05-2014, 11:29 PM   #6
Rewards Points: 16
Would I be voiding the flooring warranty? The flooring installation instructions clearly state to use 15# felt paper meeting ASTM D4869 standards.
Best way to prep and paint a 42 foot exterior wall with 3 feet eaves? Homerepairguy Painting 4 09-01-2014 01:44 PM
Etching after prep tool? aodfan Concrete, Stone & Masonry 12 05-28-2013 08:25 AM
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 05:03 PM
Level 5 Smooth Wall + Priming fred s Drywall & Plaster 10 11-10-2010 04:54 PM
Sub-base/footer prep for pavers on canal rkh2619 General DIY Discussions 1 03-08-2009 08:39 PM
