Subfloor Sagging - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2015, 09:28 PM   #1
Rewards Points: 14
subfloor sagging
Installing a subfloor over a cement slab to make it level with the rest of the house. Everything is going well, gluing and screwing all the T&G 3/4 plywood into the joists. 24" OC with blocking every 4 feet. Have put in about half the flooring and it seems very strong... but when we walk over one particular section, it makes a "crackly" noise.... like stepping on leaves almost and seems weak. It seems isolated to about a 2x4 section.
What could be causing this? Do I need to replace this piece of subfloor? Should I just cut out the offending section, install some more blocking and replace with some more 3/4 scrap I have?
scanale42 is offline   Reply With Quote
Old 06-26-2015, 09:53 PM   #2
Registered User
Rewards Points: 526
Take that panel up and install another in its place, check for sound... Did you add a waterproof material to the slab before the framing, esp. if a garage addition? Did you glue the tongue and groove joints as well? Could be the glue in ply separating from factory install defect... or add blocking there.
Gary
Old 06-27-2015, 06:53 AM   #3
Rewards Points: 18,384
Slabs are never flat, may need some shims.
Did you crown the joist before installing?
Old 06-27-2015, 09:39 PM   #4
Rewards Points: 14
Thanks, I ended up pulling up the sheathing panel in question and replaced it. Went swimmingly after that. The sheet was defective it appears.
The Following User Says Thank You to scanale42 For This Useful Post:
Gary in WA (07-03-2015)
