Subfloor Prep For Thinset - Flooring - DIY Chatroom Home Improvement Forum
Old 04-10-2018, 09:38 AM   #1
Rewards Points: 48
Subfloor Prep for Thinset
Do I need to fully remove, scrape or grind, the old glued paper backing of vinyl sheet goods (vinyl layer removed) before I apply thinset to the plywood subfloor? or does a coat or two of primer work ok. This to go under backerboard for tile.
bob7796 is offline   Reply With Quote
Old 04-10-2018, 02:13 PM   #2
Rewards Points: 4,170
Re: Subfloor Prep for Thinset
Yes and you also remove any 1/4" underlayment on which the vinyl was placed.
Note: Answer was made strictly to question asked, no judgment was made whether the subfloor or joist structure is sufficient for tile since no information about either was provided.
stick\shift is offline   Reply With Quote
Old 04-10-2018, 03:45 PM   #3
Rewards Points: 48
Alright, I am assuming that the joist system is sufficient, though, how do I check it? And I've figured I should reinforce around the toilet drain.
The vinyl was original to the house, so layed over the original subfloor, no other sub floor or underlayment.
Old 04-10-2018, 06:48 PM   #4
Rewards Points: 48
Subfloor is total 1" (3/4" + 1/4")
Joists are 9" x 1 1/2", 16" on center, 11" span between outside wall and center of house supports. Toilet side wall partition sits directly on joist. Opposite side wall partition is 2" from joist. Wide of bathroom is 3 joists wide. Actual dimension of room is 5' x 4 1/2'
Old 04-11-2018, 10:47 AM   #5
Your joists sound fine but that 1/4" layer in the subfloor needs to come out. Personally, I would replace it with at least another 1/2" if not 3/4" layer of plywood and the 1/4" cbu.
Old 04-11-2018, 11:46 AM   #6
Rewards Points: 48
I see. creates about a 1/4" height difference with hallway. But that is what transitions are for.
