Sub Floor Thickness Question - Flooring - DIY Chatroom Home Improvement Forum
Old 02-27-2018, 08:54 AM   #1
Rewards Points: 54
I'm replacing some rotted out sub floor. The part I outlined in red will also be cut out and replaced. The existing sub floor is 23/32" thick. I have a 4'x8' sheet of 19/32" sub floor. After it's replaced I'm going to put a layer of thin set down, then 1/4" cement board, and then tile. Is it possible to use the 19/32" stuff I have and build it up an 1/8" or should I just buy a sheet of 23/32"?
Sremed60 is offline   Reply With Quote
Old 02-27-2018, 09:55 AM   #2
Rewards Points: 4,170
Re: Sub Floor Thickness Question
23/32" probably isn't thick enough in the first place. What's the size, spacing and unsupported span of the floor joists?
stick\shift is offline   Reply With Quote
Old 02-27-2018, 07:51 PM   #3
Rewards Points: 54
The joists spacing is 24". 23/32" is what the builder put in. The house was built in 2000. It's a well known builder in the area and obviously it passed inspection.
At any rate, I went and bought a sheet of 23/32" to match it. I only need less than half a sheet and I'll never have any use for the rest of it - but that's life. Maybe Habitat for Humanity can use it.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
