Stretching Seamed Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 01-15-2016, 05:46 PM   #1
Rewards Points: 72
Stretching seamed carpet
I've done a fair amount of carpet work over the years for myself, family, and friends. Mostly bedrooms and living rooms with a little seaming here and there for things like closets and rooms bigger then the carpet.
Have a family member that has a bigger living room that is 15'x26' and then a hallway off it that they would like to put carpet in. My concern is about stretching the carpet after seaming it. I plan to get one piece 12x26' and then another piece 12'x9' so I can cut it up into 4'x9' piece and seam them together and then seam the new 4'x27' piece to the 12'x26' piece to complete the room.
Any tips on stretching a big carpet that is seamed together like this? Thanks
ponch37300 is offline   Reply With Quote
Old 01-15-2016, 06:08 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 396
Stretch the LR . Then stretch across the part of the hall that will attach and then seam it on.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-15-2016, 09:04 PM   #3
Rewards Points: 72
What about the living room where there will be a 26' long seam? The living room is 15x26 so it would need one piece 12x26 and then have to make the other 3x26 piece to seam together in order to make the 15x26 piece for the living room.
This is what I am picturing
Just not sure the order to seam and stretch it?
Old 01-15-2016, 09:28 PM   #4
Rewards Points: 396
Seam it into one piece and then stretch it.
The Following User Says Thank You to rusty baker For This Useful Post:
ponch37300 (01-15-2016)
Old 01-15-2016, 10:56 PM   #5
Rewards Points: 72
Easy enough. Just wasn't sure if stretching that big of a piece would be a problem with that long of a seam. Thanks
Old 01-17-2016, 08:43 PM   #6
Rewards Points: 1,900
Put the strip of three pieces on the side likely to be low-traffic, like under a sofa.
ChuckF. is offline   Reply With Quote
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Stretching carpet 10ecEd Flooring 4 05-02-2010 05:43 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Stretching Carpet nitetrane98 Flooring 1 09-23-2007 06:06 PM
