Stopping/starting VCT Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 02-06-2015, 09:55 AM   #1
liscenced electrician
Rewards Points: 540
stopping/starting VCT installation
I have more square footage to do than I can install in 1 day. Is there anything I need to know to stop and start back up, without it being obvious where I stopped? Does the glue stick up enough that I need to scrape it off, or do I even need to worry about it?
jimmy21 is offline   Reply With Quote
Old 02-06-2015, 10:25 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
As thin as the adhesive goes on, I wouldn't worry if you go a couple inches more than you cover.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-06-2015, 03:07 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Do the math, stop applying adhesive where the tile installation for the day will end.
XXX
Old 02-12-2015, 09:07 PM   #4
Rewards Points: 540
that wasn't really what i meant. I snapped a chalk line where i was stopping. Its hard to stop the glue EXACTLY on the line. I glued probably an 1/8" past the line in most spots, i wasn't sure if i needed to scrape the extra glue off the next day because that will make a highspot or does it matter. The next day do i just start glueing where i left off?
Old 02-13-2015, 08:09 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
YES! Scrape off any overage before beginning again the next day. You will have lippage if you don't.
XXX
Victim of improper Roofing installation. tbirleffi Roofing/Siding 9 06-06-2013 11:45 AM
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 07:42 PM
Kitchen and Living Room Installation bejscott Insulation 1 08-10-2012 01:18 PM
Bamboo Flooring Installation - subfloor question Shazza Flooring 5 03-19-2011 02:34 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 03:59 PM
