Staining Brazilian Cherry - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By stick\shift
Old 03-11-2019, 08:57 PM   #1
Rewards Points: 286
I have about 2500 square feet of brazilan cherry, 10 years old and needs to be sanded down and refnished, 500 square feet of tile that i want remove and replace with matching brazilian cherry.
I do not like the color from brazilian cherry, so from the little research i have done the best bet is to stain it a dark brown color.
will I be able to match the new and the old floors once i sand down the finished floor to a raw -unfinished floor? is it basically the darker the more chance the red /orange wont come out in the floors over time, and is darker the better chance to match the floors?
moneymm22 is offline   Reply With Quote
Old 03-11-2019, 09:55 PM   #2
Rewards Points: 4,748
Re: Staining Brazilian Cherry
Yes, the darker the stain, the more likely you are to get a match. That said, cherry can be difficult to stain so I would practice on a couple boards to get the process right.
Dave Sal and mark sr like this.
stick\shift is offline   Reply With Quote
Staining cherry? gizzygone Painting 5 12-09-2016 11:51 AM
Advice for hardwood flooring and stairs. Brazilian Cherry? km782 Flooring 9 01-05-2016 03:54 PM
Staining a Cherry Hardwood Door edahlke Painting 4 12-03-2014 06:26 AM
transition from brick floor to brazilian cherry floor rockey Flooring 4 12-08-2008 12:55 PM
possibly pulling up recently laid Brazilian Cherry wood floor rockey Flooring 6 11-05-2008 01:03 PM
