Squeaky Floors Under Floating Hardood - Flooring - DIY Chatroom Home Improvement Forum
Old 05-22-2016, 08:57 PM   #1
Rewards Points: 202
Squeaky Floors under floating hardood
Running into an issue with our hardwood floors which are floating & glued together at the seams. There are a few spots in which there is quite a bit of squeaking. The basement is finished, so wondering the best way to handle this. My thoughts thus far are one of two options:
1) pull up trim and try up floor as much as I can and sneak a few screws into the subfloor and joists, then put it back down
2) cut out a section of the floor above the problem area, then throw some screws in, then glue that section back in with a spare piece I saved from the original install.
Please help!
arminius is offline   Reply With Quote
Old 05-23-2016, 06:54 AM   #2
Rewards Points: 18
Re: Squeaky Floors under floating hardood
Have you considered cutting the drywall from the badement ceiling and the trying glue and screws from below? Drywall is easier to repair than flooring, in my opinion. Just my 2 cents.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 05-23-2016, 06:58 AM   #3
ZTMAN's Avatar
Rewards Points: 338
Before I started ripping things apart, I would try the "Hardwood Squeak Elimination Kit" at HD. If that does't work, start ripping
ZTMAN is offline   Reply With Quote
Old 05-23-2016, 08:05 AM   #4
Rewards Points: 202
Looks great, but I've installed a floating floor, and i'm pretty certain (though not for sure) the squeking is coming from the subfloor. So I don't think it would fix it.
Old 05-23-2016, 08:06 AM   #5
Rewards Points: 202
I tried that b4 I finished my basement using shims and glue. Didn't fix it, even though it make some progress.
Old 05-23-2016, 08:13 AM   #6
Rewards Points: 18
I am also agreeing that it is coming from the subfloor. My suggestion of glue and screws would be to tighten the subfloor to the joists by prying up the subfloor slightly above the joists and injesting some construction adhesive between them and then toe screwing through the joists into the subfloor. Not sure if it will work or not but worth a shot before ripping part of the floor.
Tags
floating floor , squeaky floor
bouncy squeaky floor, but wait there's more, free floating sills notso99 Building & Construction 18 12-28-2013 08:55 AM
Squeaky Floors-Wood Putty for Hardwood Floors that are Finished?Help HandyFrank Flooring 7 12-15-2012 07:37 AM
Installing Hardwood Floors - Is floating the floor required? DrTude15 Flooring 5 11-26-2012 10:30 AM
Squeaky floors phantasm72 Flooring 2 02-20-2011 08:14 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
