Squacking Noise - Flooring - DIY Chatroom Home Improvement Forum
Old 03-25-2014, 11:26 PM   #1
Squacking noise
Hello I just recently moved into my grandmother house, which is 30 to 40 years old. All bedrooms have the original hardwood flooring. Each room has different areas that makes noises when you walk over it. If you have any suggestions please let me know it would be greatly appreciated.
newtda is offline   Reply With Quote
Old 03-26-2014, 12:04 AM   #2
Rewards Points: 18,502
Not a whole lot you can do about it.
Any access under the floor?
One trick is to use baby powder on the gaps and sweep it in to the cracks.
If the floor joist are flexing they can be sistered.
Old 03-26-2014, 12:06 AM   #3
There is access to the flooring from the basement.
Old 03-26-2014, 10:50 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 780
You didn't list your location when you signed in, think it might help with this?
What is the relative humidity in the house right now?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 03-26-2014, 11:20 AM   #5
Low humidly causes the wood to shrink. It should be about 45%.
Old 03-26-2014, 11:25 AM   #6
The humidity is right around 40%, I live in Cincinnati Ohio
Old 03-26-2014, 11:53 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
OK, 40% isn't bad this time of the year depending on the outdoor temp. It's best to keep it at 45 or above, but nearly impossible and not good for the rest of the house when it's cold. It won't be hard to go to above 45% soon.
Wood floors will eventually squeak, it's the law. If yours is real bad you may be able to reduce the noise, maybe. Try the talc/baby powder method. Might be able to fix it better next time the floor is re-finished.
Jaz
Old 03-28-2014, 11:17 PM   #8
You will find these squeaks in almost all the wood floored houses, can't do much about this. But can try putting thick rug at places where squeaks happens, it will reduce the pressure on the wood and maybe there will be an lesser noise. Try putting some cloths at that place and walk over it, see if it works. If it does, then buy the rug. :D
Mike_Watts is offline   Reply With Quote
Old 04-01-2014, 03:51 PM   #9
Rewards Points: 744
How's that?
Seattle2k is offline   Reply With Quote
Old 04-11-2014, 02:22 PM   #10
TheOldPro's Avatar
Does it have subflooring?
TheOldPro is offline   Reply With Quote
Rattling Noise from Roof when windy drgillian Roofing/Siding 6 10-17-2018 07:35 AM
Condenser fan noise and then blade breaks. whotheguy HVAC 11 09-30-2013 07:59 PM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Frigidaire freezer noise (sounds like a compressor) onelove Appliances 3 10-09-2010 09:16 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
