Spiral Shank Nails - Flooring - DIY Chatroom Home Improvement Forum
Old 05-02-2014, 02:55 PM   #1
Rewards Points: 150
spiral shank nails
I am installing 1/2" hardwood, 5" wide plank flooring over 3/4" OSB. The manufacturer recomends using "spiral ring shank nails" for nailing the tongue adjacent to the walls. (When the nailer won't fit). The heads on these things are much larger than a finish nail, it looks like it it might be tough to sink them and would get in the way of the tongue-to-groove connection. Are finish nails ok for this, or will they slip and squeak?
joemontana16 is offline   Reply With Quote
Old 05-02-2014, 04:31 PM   #2
Rewards Points: 1,366
There is a reason that the manufacturer recommends a spiral nail....and that is because it holds better than a finish nail. I JUST (well, maybe a couple of hours ago) used some of these in the 2 1/2" length to sock in place a set of fir treads for a basement. Go to a real lumberyard and peruse their selection. The ones that used had a head not much bigger than an 8d finish nail...and had a depression in the head for easy countersinking. Ron
ront02769 is offline   Reply With Quote
Old 05-02-2014, 04:41 PM   #3
Rewards Points: 17,912
Never once heard of that one.
Got a web site with the install directions?
woodman58 (05-02-2014)
Old 05-02-2014, 04:57 PM   #4
Rewards Points: 1,472
I doubt a finish nail would ever squeak very long because if you start walking adjacent to the wall your wife will surely have you committed.
Old 05-02-2014, 07:00 PM   #5
Website says to just bang them with your hammer and countersink. Easy to handle.
But I DID just walk all the way out to the garage to read the box, GripRite THS Screw Flooring 7d 2 1/4 inch (my bad on the 2 1/2")
Ron
Old 05-02-2014, 07:50 PM   #6
Rewards Points: 150
Here is the link to my manufacturers installation instructions...I'll have to check out the ones with smaller heads, the only ones I have seen won't fit in the small groove of this stuff. It's 1/2" thick. (Says "spiral roll shank nail" not "spiral ring shank nail")
http://www.builddirect.com/Hardwood-..._10090528.aspx
*Bonus Questions*...Due to the narrow groove, the splines I ordered don't fit. Any tips on making my own splines/slip tongues? Groove is less than 1/4" tall.
Old 05-02-2014, 08:39 PM   #7
woodman58's Avatar
I agree with joecaption. Never heard of this. Finish nails are all I have used in 30 yrs. If not using air nailer drill first.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 05-02-2014, 09:27 PM   #8
Rewards Points: 150
Thanks guys! I just measured the gap created by the two grooves butted together. (For spline). It is 1/8 x 3/8. I have a hard time seeing that small let alone making a cut. I might try planing/shaving the ones down that I bought - they are 1/4" x 1/2".
Me ranting about nails... Pittsville Building & Construction 16 12-27-2018 04:08 PM
Ring Shank Nails Shuriko General DIY Discussions 4 06-18-2012 10:44 PM
Source for roofing nails, 3" long, ring shank? buzzymalone Roofing/Siding 7 07-27-2009 10:58 AM
Can I use ring shank nails for framing? bluefitness Building & Construction 3 12-18-2008 09:17 PM
