Smaller Than 1/4 Inch Gap Ok? - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 08-09-2019, 10:44 AM   #1
Rewards Points: 124
Smaller than 1/4 inch gap ok?
I installed Smartcore pro vinyl planking in my kitchen and dining room. The recommended gap between each wall is 1/4 inch. In some spots it is maybe half of 1/4 inch.
Is this really that big of a deal, should I rip up all the work and make sure it is 1/4 inch. None of it is directly touching the wall, just the gaps in some spots are much less than others.
The other issue is that the pre-existing trim would barely fit to conceal the edge in some spots.
tuffguy01 is offline   Reply With Quote
Old 08-09-2019, 10:50 AM   #2
retired framer
Rewards Points: 20,612
Re: Smaller than 1/4 inch gap ok?
I would be asking about the best way to cut that little bit off with out ripping it out. Maybe a multi saw.
CodeMatters likes this.
Do not use flat bottom gables with scissor trusses.
