Sleepers? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-26-2014, 08:32 PM   #1
deverson's Avatar
Rewards Points: 77
Have a very small house that in 1947, when it was built was a garage. The 2 floors are a different height. Kitchen and bath got treated 2x4's styrofoam vapor barrier and 3/4" T&G sheathing. The living room floor doesn't give me that luxury. Is it acceptable to lay 3/4" foam and anchor plywood directly to the top of the foam with FH tapcons? Thanks in advance.
deverson is offline   Reply With Quote
Old 10-27-2014, 07:17 AM   #2
Retired Moderator
Rewards Points: 7,174
I've done exactly what you are planning---I sure had my doubts about the life of the floor---however,after 12 years,it is still perfect----covered with ceramic tile---in an unheated sun porch--
Old 10-27-2014, 09:28 AM   #3
Rewards Points: 18,384
I've also done it in a kitchen in a slab home.
It broke the thermal barrier so the floors are warmer and it's rock solid.
oh'mike (10-28-2014)
Old 10-29-2014, 01:32 AM   #4
Rewards Points: 108
It is perfectly fine, you can apply plywood directly to the top of the foam.
RobertCurry is offline   Reply With Quote
Old 10-29-2014, 02:02 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 17,742
I can see how the plywood on top of the foam would be really stiff. The plywood would do a great job is distributing the weight.
If one was concerned about deflection....going to 1 1/8" T&G would be a significant improvement. I have 1 1/8" T&G on my second floor. It's about par to walking on cement.
Waterproof material for sleepers on flat roof dftc Carpentry 9 09-05-2014 12:45 PM
Using PVC decking as sleepers arkinect Flooring 5 09-03-2012 11:56 PM
Deck construction - spacer under sleepers Quercus Building & Construction 9 06-24-2012 03:21 PM
Rot-proof spacer under sleepers? Quercus Building & Construction 2 06-18-2012 10:20 PM
How to attach sleepers to a sloped concrete slab mcherno Building & Construction 4 07-08-2009 07:37 PM
