DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Flooring (https://www.diychatroom.com/f5/)
-   -   Should wood planks run parallel or perpendicular to doorway (https://www.diychatroom.com/f5/should-wood-planks-run-parallel-perpendicular-doorway-149671/)
EFTHIM 07-09-2012 11:35 AM
Want to install hardwood floor. Do i install planks perpendicular or parallel to doorway? Does it matter if planks are not perpendicular to floor joists? My floor is 16 o.c. - 2x10. thanks
TarheelTerp 07-09-2012 11:47 AM
Originally Posted by EFTHIM (Post 961515)
Do i install planks perpendicular or parallel...
generally... flooring is run in the long direction of the house/room.
but there are no laws to prevent other choices being used
CopperClad 07-09-2012 11:50 AM
As long as it's T&G you can run it in any direction you can think up. Good luck !
JetSwet 07-09-2012 06:40 PM
I don't know if that's entirely true, If the subfloor is of adequate strength then you could run it any way.
CopperClad 07-09-2012 06:47 PM
Sorry.. They said 2x10's 16'' OC, I suppose I assumed it was T&G 3/4ply. To clarify.. When was the home built and what kind of plywood is sitting on top of your 2x10's?:)
EFTHIM 07-15-2012 12:53 PM
The flooring is OSB and is T&G.
JetSwet 07-15-2012 01:23 PM
Then if your laying over osb T&G any way is fine, suggestion to run it longest way of the room would look better I think.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
