Sheet Vinyl Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 05-20-2016, 08:43 AM   #1
Rewards Points: 155
sheet vinyl over tile
my neighbor has a rented condo- She asked me to cut and lay sheet vinyl over the existing tile floor- I'm not crazy about it - but it's not my bathroom- All the other bathrooms in most of the units have the same thing. What type of adhesive would I use to at least glue down the ends but not make it so hard to get back up?
Huskyfan68 is offline   Reply With Quote
Old 05-20-2016, 09:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Re: sheet vinyl over tile
The tile joints will telegraph thru the vinyl.
If you must use a loose lay vinyl. Consider Coretec Plus.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-20-2016, 11:39 AM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
Ceramic tile? Any vinyl-backed vinyl will work for a while. I would use Flexitec, it is cheap for a temporary floor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Have this sheet vinyl floor asbestos tested? CoconutPete General DIY Discussions 11 01-21-2012 10:39 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 12:39 PM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 10:58 AM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
