Seeking 1-1/2" Flooring - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By SPS-1
  • 1 Post By ndenni01
Old 08-09-2019, 12:34 PM   #1
ndenni01's Avatar
Rewards Points: 30
We are working on a very old home with 1-1/2" flooring in all rooms, except two with carpet. We'd like to remove the carpet and replace with 1-1/2" flooring to match as closely as possible to the remainder of the home. The key is FINDING 1-1/2" flooring. I've attached a photo of the current flooring.
ISO recommendations for businesses to contact for reclaimed (preferred) or custom milled ($$ ouch!) 1-1/2" tongue and groove hardwood planks. We need approximately 400 sq. ft. of material.
Please recommend only businesses you've personally worked with and preferably in the southeast United States. The closer to Tennessee the better.
Seeking 1-1/2" Flooring-78ebfe4b-4b89-4503-9224-9c50562a873e.jpeg
ndenni01 is offline   Reply With Quote
Old 08-09-2019, 12:43 PM   #2
retired framer
Rewards Points: 20,394
Re: Seeking 1-1/2" Flooring
https://www.flooring.org/1-12-Red-Oak-Strip-Flooring
ndenni01 likes this.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
ndenni01 (08-13-2019)
Old 08-09-2019, 02:52 PM   #3
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,196
Originally Posted by ndenni01 View Post
...1-1/2" flooring to match as closely as possible to...
That looks like 3" strip from here.
Old 08-09-2019, 03:42 PM   #4
retired framer
You need stronger glasses?
Old 08-09-2019, 07:34 PM   #5
MarginallyQualified
I'll stick.
Old 08-09-2019, 07:44 PM   #6
retired framer
I'll stick.
really
Old 08-10-2019, 09:48 AM   #7
MarginallyQualified
^^What he said.
Seeking 1-1/2" Flooring-3-strip.jpeg
Old 08-11-2019, 09:58 AM   #8
sestivers's Avatar
Rewards Points: 329
The line at the 1.5" mark and the one at the 4.5" mark are quite faint, but you should be able to see the different grains on each side of those lines to know they're different boards. It looks almost like two 1.5" planks were joined at the factory to make a 3" plank.
If it's easier to get 3" planks maybe you could score it down the center so it looks more like the existing flooring?
Steve
sestivers is offline   Reply With Quote
Old 08-11-2019, 11:05 AM   #9
Rewards Points: 7,548
To me, it simply looks like the wood has dried a little, creating some gaps. Location of gaps is going to be random.
SPS-1 is online now   Reply With Quote
Old 08-11-2019, 11:25 AM   #10
MarginallyQualified
The line at the 1.5" mark and the one at the 4.5" mark are...
... are not the T&G installation joints.
Old 08-13-2019, 03:40 PM   #11
ndenni01's Avatar
Rewards Points: 30
Thank you. Have you ever purchased flooring from flooring.org? I'm always hesitant to make a large purchase from an online retailer without references.
Old 08-13-2019, 03:45 PM   #12
ndenni01's Avatar
Rewards Points: 30
I HAVE considered scoring 3 planks. But Ive got time to wait for the right thing so am keeping hope.
Old 08-13-2019, 03:46 PM   #13
ndenni01's Avatar
Rewards Points: 30
Definitely separate planks.
Seeking 1-1/2" Flooring-53e5d5f7-c714-429c-99a5-df8536766c9e.jpg
Nealtw likes this.
Old 08-13-2019, 04:31 PM   #14
At least that flooring site specifies a grade to their selections. Sometimes you only get what you pay for. Note that their description shows random lengths. If the price is very good, then best to buy quite a bit extra, because you likely a heck of a lot more of the one footers than of the seven footers.
Tags
flooring , hardwood , millwork , reclaim , thin plank
