Seam Binder Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 02:49 PM   #1
Seam binder questions
So I want to install seam binders in my house there is already carpet and tile down but there are small areas that it's fraying and tile is a little chipped in places. this is why I want to put a seam binder here are my questions.
1. Do I need to pull the tack strip up or drill through it into concrete?
2. How would I make a 90 degree turn without it being ugly/sharp?
3. After dowells are in how do I know where to hammer if I can't see the dowells with the carpet over lapping?
I have been told to drill holes and insert dowells then hammer the nails that come with the binder similar to this http://www.hardwarestore.com/pop-pri...x?prodNo=79345
Thanks!
Tryskylife is offline   Reply With Quote
Old 02-04-2012, 10:51 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
#I drill thru
#2 Overlap, mark and cut 45
#3 The holes in the seam binder (flat metal) are already drilled. just measure where they are so you know where to drill. They when you nail, you can't miss the dowels.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-06-2012, 11:31 AM   #3
Thanks a lot I really appreciate it and it came out pretty nice! It was tough to get the holes drilled in the right place, in some places the bit would walk away from it's hole but all in all a great learning experience!
Old 02-06-2012, 12:33 PM   #4
Rewards Points: 398
It looks good.
Basement Finishing Questions lmf232s Remodeling 3 01-20-2012 10:04 PM
Visible seam on fixed hole in ceiling? kcrossley2 Drywall & Plaster 24 06-18-2010 08:58 AM
Standing seam roof questions Tscarborough Roofing/Siding 9 03-15-2010 08:03 AM
Hanging Drywall to a finished Ceiling, Seam Questions? Worker-B Drywall & Plaster 5 08-24-2009 10:40 AM
recaulking: cleaning out old caulk questions adamc Painting 6 09-19-2008 06:30 PM
