Seal Before Grout??? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-25-2010, 11:32 AM   #1
I have these natural stone tiles set and dried. Do I need to seal them before I grout? I did the kitchen and entry last year but can't remember what order I did them in. I think that I sealed prior to grout to prevent any grout stains. Also what would be the best method of applying the sealer since the tiles are uneven? Any help would be greatly appreciated
MedicPelle is offline   Reply With Quote
Old 11-26-2010, 06:51 AM   #2
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Yep, Grout Release would be the first step. This is a type of sealer designed to keep the grout from staining the stone. I'd apply it with a paint brush if it is very uneven. If it isn't too bad you could use a paint roller to make things go a bit quicker.
poppameth is offline   Reply With Quote
Old 11-26-2010, 02:40 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes, slate tile should be sealed before grouting, maybe a couple of times. Then again after the grout has dried.
XXX
Old 11-27-2010, 07:37 AM   #4
KCB
man i love that floor as the others have said , try not to get the sealer in the grout line .Seal only the surface of the stone.2 coats is best .
KCB is offline   Reply With Quote
do i need to seal grout? wombosi Tiling, ceramics, marble 5 01-20-2011 03:44 PM
Restoration Grout Seal jjd Tiling, ceramics, marble 0 06-09-2010 11:45 AM
First tiling project. Time to grout and seal. speedster1 Tiling, ceramics, marble 5 04-26-2010 07:28 AM
Bleach then seal grout? Bacardi 151 Flooring 1 11-29-2008 11:23 AM
Do Tile setters seal grout? Yeti Flooring 2 10-24-2007 06:18 PM
