Running Laminate Different Directions - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2016, 12:07 PM   #1
Rewards Points: 126
Hi all,
My home has existing hardwood floors, but they are in bad shape in some areas (previous owner pet stains, cupping, etc.). I've been thinking of adding laminate (with underlayment) on top of the existing hardwood. That way if I ever want to go back to the original hardwood one day I yank up the laminate and there it is.
Here's my question: I would like to do the living room, dining room and hallway the same finish, but do a different finish in each of the bedrooms. Two bedrooms will be running in the same direction as the hallway, but one bedroom I would like to run perpendicular to the hall. I would like the transition to be smooth without needing a transition strip (hopefully) for a seamless look.
As long as the floor is fairly flat and I use the same thickness laminate and underlayment then I don't think it would be that big a problem. What's the best way to connect the hallway laminate to the perpendicular laminate?
TeeRiddle is offline   Reply With Quote
Old 01-13-2016, 08:34 AM   #2
Rewards Points: 18,384
There is no way to do it with laminiate without a trasition strip.
I also would not be laying it over a floor that's cupped.
Hollow sounds when walking on it, flooring flexing causing the joints to open up.
Laminate Floor Install - Advice? cmvsm Flooring 18 07-02-2013 02:18 AM
Laminate floor in basement questions ryoung25 Flooring 8 09-15-2010 11:33 PM
Laminate over laminate jho Remodeling 12 06-10-2010 03:56 PM
Laminate layout, underlay for concrete subfloor? Jen25 Flooring 2 09-30-2008 01:04 AM
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 08:07 AM
