Replacing Upstairs Carpet With Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2015, 10:57 PM   #1
Rewards Points: 2
replacing upstairs carpet with hardwood
We are replacing the upstairs carpet with hardwood, 3/4" X 4" wide hickory. The problem we are running into is the upstairs is split at an angle. The top landing, master and first bedroom run north/south, the two back bedrooms and hallway are at a 30°angle from there.
How do we match the two together.
Where do we put the seam.
Should we run a board perpendicular to the hallway and butt both sides up to it?
Any suggestions and/or pictures would be great.
mrfixit888 is offline   Reply With Quote
Old 06-29-2015, 05:46 AM   #2
Retired Moderator
Rewards Points: 7,174
Post a sketch of the layout----hardwood is usually all laid in the same direction ,so I am unclear what your needs are,
Tags
angle , hallway , hardwood
Hardwood stairs, carpet upstairs Mepcguy Flooring 5 03-24-2013 11:26 PM
Hardwood or Carpet on Stairs? RugbyLove Flooring 3 11-16-2011 04:19 PM
Replacing Carpet on Stairs with Hardwood Treads Funnyflip Flooring 2 10-24-2011 08:57 AM
Stairs - Match Upstairs or Downstairs Hardwood? arubatan Flooring 1 09-22-2011 10:10 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 09:35 AM
