Replacing Subfloor For Bathroom Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 03:46 PM   #1
Replacing subfloor for bathroom tile
Hi again. The wife has me on a new project. I have yet to rip any flooring up as I wanted to get some opinions first
I want to replace linoleum in a 2nd floor bathroom on a house built in 2000. The joists appear to be prefab 19"oc (9.5" tall, 2.5" wide, with the plywood style centers.. not solid wood). I don't know the span.
The subfloor layer is 3/4" chipboard
There is a 3/8" MDF sheet over that.
I am aware I will have to tear the MDF out and put down plywood due to water concerns, so I am trying to figure out how thick this should be first. Ideally I will be changing adjacent flooring to hardwood in the future, so if I can have as little of a transition as possible, that would be best. With a ~3/4" hardwood, that would give me 3/4 to play with in the bathroom for tiling. If the tile/cement is aprox 3/8 thick, that leaves me with 3/8" for a top layer of plywood.
Do you think 3/4" chipboard + 3/8" plywood (1-1/8 total thickness) is sufficient for ceramic tiles (I haven't even considered tile size yet).
Any input is appreciated.
THANKS!
Drizzt is offline   Reply With Quote
Old 07-06-2013, 04:11 PM   #2
Retired Moderator
Rewards Points: 7,174
We will need that joist length---
Adding 3/8 or 1/2 inch BC ply will be enough for your 19" centers---
Old 07-06-2013, 04:18 PM   #3
I'm not well versed in structural support. How could I determine this, short of tearing up the subfloor or tearing out my main floor ceilings? Is "joist length" the distance between supporting beams? I have an unfinished basement where I can see all the supporting beams, but I don't know if that translates all the way up into the 2nd story.
Old 07-06-2013, 05:38 PM   #4
Retired Moderator
On a second floor --measure the ceiling down stairs from outside wall to the next supporting wall---
Old 07-07-2013, 01:10 AM   #5
It looks to be 15' from outside wall to the next supporting wall, directly under the bathroom on the main floor.
Old 07-13-2013, 04:01 PM   #6
Rewards Points: 150
Since no one else replied.
Based on your description (9 1/2" I-joist with 2 1/2" flange spanning 15 Ft @ 19.5 oc and ceiling below) your floor will not exceed L/720 and T/480 deflection required for tile. Even though 5/8" subflooring can be rated to span 19.5, I would go with 3/4" under tile.
There are a lot better qualified people to advise you on building the floor on the structure.
goosebarry is offline   Reply With Quote
Old 07-13-2013, 04:09 PM   #7
Based on your description (9 1/2" I-joist with 2 1/2" flange spanning 15 Ft @ 19.5 oc and ceiling below) your floor should not exceed L/720 and T/480 deflection required for tile. Even though 5/8" subflooring can be rated to span 19.5, I would go with 3/4" under tile.
Thanks for the reply. So my 2 layers of ply over the joists (3/4" and 3/8") totaling 1-1/8" should be enough. Unless I'm misunderstanding you, and you say that I should have (3/4" and 3/4") totaling 1-1/2"
Old 07-13-2013, 04:50 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
I wouldn't do 3/8 I would do 1/2" if your joist is that far apart. Both layers should be perpendicular to joist and seams offset a foot on 2nd from 1st layer.
JetSwet is offline   Reply With Quote
Old 07-13-2013, 09:27 PM   #9
Rewards Points: 150
3/4 for the bottom is for structural reasons. I'll defer on the top layer to the tile experts.
Old 07-13-2013, 09:41 PM   #10
Pro
JetSwet's Avatar
Rewards Points: 502
Both layers of plywood are for structure.
Then it's either backer board which should be 1/4" or a ditra membrane.
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
replacing wall tile on uneven surface johnpaul8379 Kitchen & Bath Remodeling 2 02-22-2011 03:26 PM
Replacing shingles with tile. Support needed? meltdowndave Roofing/Siding 4 07-11-2009 03:33 PM
Replacing clay tile roof with shingles Sparky 55 Roofing/Siding 1 03-26-2009 10:08 PM
Replacing kitchen countertop tile budget consciou Remodeling 5 03-17-2009 09:24 AM
