Replacing Sleepers - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By stick\shift
Old 02-06-2017, 12:59 PM   #1
Rewards Points: 4
Unhappy
Replacing Sleepers
HELP!!! Yesterday, I pulled the carpet up in my sunroom. I found that the cement beneath is crossed with two sleepers. They are damaged as the result of moisture. I went outside to determine origin of moisture and found that the sleepers actually run outside. This room was added on top of an original slap area that was used as a patio and no one explained that the sleepers needed to be addressed prior to building a room on top of it. Now I am at a loss. What are my options for filling in the sleepers once they are removed; especially since they run outside. Can This area be filed in with cement, a special sealant/epoxy or do I have to use pressure treated wood? I really want to seal this up; separate the outside area from the interior. HELP!!
CG_7274 is offline   Reply With Quote
Old 02-06-2017, 02:20 PM   #2
Rewards Points: 4,170
Re: Replacing Sleepers
How about some pictures so we can see what you're seeing?
joecaption likes this.
stick\shift is offline   Reply With Quote
Old 02-06-2017, 05:19 PM   #3
Rewards Points: 4
I added some pictures. There is some adhesive covering portions of the boards between the cement, but I pulled enough off so that it can be seen.
Tags
cement floor , sleepers
Replacing old delta with new delta trim, without replacing entire unit BERWYNpap Plumbing 6 02-05-2016 10:09 PM
Replacing old wall heaters clander Electrical 7 01-27-2016 10:56 AM
Rot-proof spacer under sleepers? Quercus Building & Construction 2 06-18-2012 09:20 PM
How to attach sleepers to a sloped concrete slab mcherno Building & Construction 4 07-08-2009 06:37 PM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 07:27 AM
