Replacing Linoleum With Ceramic Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2014, 11:51 AM   #1
Rewards Points: 191
Replacing linoleum with ceramic tiles
I currently have a big sheet of linoleum in the kitchen and laundry room. After redoing the countertops and back splash it is time to attack the floor.
Ive removed a small patch under the fridge and it seems easy enough to remove. It's the linoleum and ten a layer of paper and what seems like plywood underneath.
The question i have to you all is how do i deal with the height difference between the dining room and the kitchen. if i were to tile over the area where the linoleum is (after it is fully removed). it would be higher than the dining area.
How do i deal with this? Will a transition be fine or should i consider removing part of the subfloor to get it even. i really dont want to touch the subfloor, but at the same time i want the floor to look really good and even.
any suggestions will be highly appreciated.
rygar is offline   Reply With Quote
Old 02-18-2014, 12:20 PM   #2
Rewards Points: 18,384
Little more to it then that.
All the linoleum and any 1/4 plywood or particle board will need to go.
Need to know the width, spacing, free spans of the floor joist and what's there now for a subfloor.
Tile floors can not have any flexing and must be flat.
rusty baker (02-18-2014)
Replacing broken brick tiles...newbie here jmiza Remodeling 3 01-25-2013 05:48 PM
ceramic tile over linoleum Devyn Flooring 8 03-17-2011 05:33 PM
Can I ceramic tile on to linoleum? brycom Flooring 6 02-22-2011 08:41 PM
stains on ceramic tiles bubby :-) Tiling, ceramics, marble 1 06-24-2009 02:05 AM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 12:25 PM
