Repair Damaged Sub Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 06:01 PM   #1
repair damaged sub floor
There are two small areas that need repair. Its about 3x10 and 4x6. How do I go about removing the particle board. Thanks.
workhorse2 is offline   Reply With Quote
Old 08-07-2011, 06:08 PM   #2
Rewards Points: 2,850
Cut away the damaged portion and go all the way to the nearest joist. Now either cut it away so half of the joist upper surface lengthwise is available for the new replacement plywood subfloor piece to rest on, or attach a 2x4 along the exposed portion of the joist as a "sister" to provide an upper edge for the new piece to rest on. Use both glue and numerous screws to hold the 2x4 sister piece on if you use that method. Suggest screws no farther than 5 inches apart and long enough to penetrate by at least an inch.
Old 03-09-2012, 12:49 AM   #3
Rewards Points: 93
Similar problem: 3/8 particle board on top of 5/8 plywood. About 60 square feet of particle board was damaged by leak under sink. Plywood in good shape.
I've stripped the bad particle board, continueing outward until I got good stuff that measured 0.375 to 0.400.
At this stage, what: Put down a new layer of particle board? Plywood? OSB? Butt the edges, or leave gaps? Right stuff to fill gaps?
sgbotsford is offline   Reply With Quote
Old 03-09-2012, 12:58 AM   #4
Rewards Points: 638
i like plywood and a 1/16 between sheets
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-09-2012, 01:36 AM   #5
Rewards Points: 18,382
Use floor leveler to fill the gaps, not foam.
Make sure whatever you use is subfloor rated.
Old 03-09-2012, 02:59 AM   #6
I like to put the sheets pretty tight, get tight as possible, any gaps under an eighth . I wouldn't fill any of these small gaps unless your are putting sheet goods over the floor
I would not use OSB or particle board, personally would use plywood (unless you are putting tile over, then i'd use backerboard instead of plywood)
chrisBC is offline   Reply With Quote
Old 03-09-2012, 09:34 AM   #7
Rewards Points: 93
Thanks. Guys. Floor leveler it is.
The intent is that this is a temp repair -- 5-10 years until I can afford to put down hardwood. I put in 7/16 OSB, but the OSB is going to need a skim coat of floor leveler to bring it up to the same level as the rest of the floor (vinyl) Then trafficmaster ceramica. Good friend in the reno biz says that it's soft enough to cope with slight variances in flat, and stiff enough to not telegraph. Home depot says that any cement like product needs to be primed. So; Floor leveler today. Prime tomorrow, tile on Sunday.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 07:37 AM
Repair wood floor scratch borderman01 General DIY Discussions 4 05-07-2010 05:13 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 03:33 PM
