Removing Tape Residue From Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 2 Post By SeniorSitizen
  • 2 Post By mark sr
  • 2 Post By lenaitch
  • 1 Post By jaketrades
Old 09-12-2018, 07:35 PM   #1
Rewards Points: 790
Removing tape residue from hardwood floors
Iíve got some tape residue on my floors. I piece of cardboard I used for floor protection had foam tape on it.
Is there some diy residue remover.
Iíve got mineral spirits, vinegar, and other household cleaner.
I donít want to buy a bottle of goo gone for 2-3 spots.
jaketrades is offline   Reply With Quote
Old 09-12-2018, 07:54 PM   #2
Rewards Points: 984
Re: Removing tape residue from hardwood floors
A solvent is going to be needed. If mineral spirits doesn't work, does your wife have any nail polish remover aka acetone? Otherwise, buy some goof off.
Marson is offline   Reply With Quote
Old 09-12-2018, 07:59 PM   #3
Rewards Points: 1,760
Don't use Goo-Gone, Goo-Gone is a cocktail of various solvents used to remove labels from glass or metal surfaces, I would never use it on anything painted or polyurethaned. I would try the Mineral Spirits, that sounds the same as Paint Thinner. Failing that I would try Naphtha from a home center. If you try lacquer thinner or acetone, test if first in a closet or under an appliance.
ChuckF. is offline   Reply With Quote
Old 09-12-2018, 08:07 PM   #4
Rewards Points: 1,550
Being I've gotten WD-40 on gun stocks with various unknown and known finishes for lots of years without repercussions when cleaning, I'd reach for my 0000 steel wool and a couple drops of WD-40.
de-nagorg and ZTMAN like this.
SeniorSitizen is offline   Reply With Quote
Old 09-12-2018, 08:17 PM   #5
Rewards Points: 790
The paint thinner got it right out. Thanks.
Another question, Iíve got a general dusty haze over my hardwood floors after vacuuming.
Iím going to clean it with a bonas wood floor mop. Is there a better way to get the dust off without damaging the floors?
Old 09-13-2018, 05:31 AM   #6
retired painter
Rewards Points: 1,838
Is this dusty haze leftover from sanding? Generally a damp mop works well. You don't want to flood the wood, just have enough moisture to grab the dust. Doing it that way won't hurt the wood.
Dave Sal and jaketrades like this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
jaketrades (09-13-2018)
Old 09-13-2018, 08:21 AM   #7
Usually Confused
lenaitch's Avatar
Rewards Points: 2,208
Jake - I recall your posts from the get-go as you renovate your condo/apartment (possibly without approval, but whatever). If you kept 'before' photos, you should post a project summary when you are done to show us your handiwork.
_________________________________________
Who Dares Wins
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
jaketrades (09-20-2018)
Old 09-20-2018, 10:09 AM   #8
Rewards Points: 790
Iíll try to dig up some pics. Couldnít have done this without you guys!
lenaitch likes this.
Old 10-28-2018, 05:39 AM   #9
Rewards Points: 790
Here are the after pictures....
Old 10-28-2018, 06:03 AM   #10
Rewards Points: 790
Found some before pics....
Refinishing Oak Hardwood Floors - Facenailed - Bona Prep and Poly JerLon Flooring 2 10-28-2014 04:11 AM
Squeeky hardwood floors jkungle General DIY Discussions 5 08-31-2014 02:30 PM
refinishing hardwood floors/ formerly varnished dianepm Flooring 3 09-13-2013 06:03 AM
where to get 1/4" thick hardwood floors? dozu Flooring 3 04-30-2011 05:17 AM
Hardwood floors installed over 1/2" and 5/8" subfloor interplexr Flooring 1 01-25-2009 01:00 PM
