Removing And Replacing Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 12-05-2014, 11:03 PM   #1
Zad
Rewards Points: 4
Removing and Replacing Tile
I screwed up. We renovated this spring and retrofitted our home with hydronic radiant heat. I poured a 2" suspended slab with radiant tubing on the main floor of the house and when I was running the tubing for bedroom I mistakenly ran it into the bathroom (wasn't clear where the door was going). So, the master bath has about 10 square feet of flooring that is heated on the much colder bedroom zone and it is not only uncomfortable but the btu's lost is making it hard to heat the bathroom on really cold nights (it was -9 F the other night). So, sadly, I am going to tear up the tile and ditra and gently bash out the concrete and fix the tubing error. I am comfortable with all of this except the part where I will need to redo the tile. Any tips or suggestions on replacing six 12" by 24" tiles on ditra so they match up with the existing flooring?
Zad is offline   Reply With Quote
Removing decorated tile and replacing with plain tile. anncollins Kitchen & Bath Remodeling 2 01-09-2013 06:47 PM
removing and replacing bathroom tile rainajz Kitchen & Bath Remodeling 1 02-11-2012 12:49 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
Removing old 6" Tile and Replacing with 6" tile Mikey_B Tiling, ceramics, marble 1 07-09-2009 10:01 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
