Removed Carpet - Quick Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 03-27-2017, 11:00 AM   #1
Rewards Points: 8
Removed carpet - quick questions
The previous owner had carpet for what I am assuming since at least 1972. Luckily, there is beautiful hardwood floors underneath. I do have a couple questions, though. As part of the refinishing, I need to know what wood this is:
Oak? Also, what is the best way to transition that particular threshold? It's a pretty big difference. Would a basic reducer work? Thanks!
oneBlessedMan is offline   Reply With Quote
Old 03-27-2017, 05:59 PM   #2
Rewards Points: 1,042
Re: Removed carpet - quick questions
Looks like something that needs to be custom made, pretty simple if you have a router mounted in a table, i make all mine as what they have in the store is way over priced.
Canarywood1 is offline   Reply With Quote
Old 03-27-2017, 07:25 PM   #3
Rewards Points: 692
What is the height difference between the tile and hardwood surfaces?
JIMMIEM is offline   Reply With Quote
Old 03-27-2017, 07:38 PM   #4
Rewards Points: 8
It's about 7/8".
Old 03-27-2017, 08:16 PM   #5
Rewards Points: 692
How about a transition strip that just covers the edge of the tile and ramps down to the hardwood at a 15 degree angle. The thickness of the edges should be 1/4". Start out with a piece that is 1 1/8" thick, 3 1/2+" wide, and as long as the doorway(?) opening. This would best be done on a router table.
Old 03-28-2017, 12:04 AM   #6
Rewards Points: 1,760
Looks like oak from here, but need a closeup to tell.
I've made 'ramp' transitions from pieces of hardwood flooring by cutting the 3/4" by whatever into a ramp using angle cuts on a table saw. Works better though when the transition is parallel to the hardwood strips. In your case it would have to sit on top.
ChuckF. is online now   Reply With Quote
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Quick Questions For Running Conduit In Walls nullqwerty Electrical 6 10-31-2011 07:41 PM
can I lay carpet over adhesive from removed vinyl tiles marshallk9 Flooring 3 03-06-2009 01:56 AM
Quick cabinet painting questions jimithing78 Painting 2 08-20-2008 12:46 AM
