Remove Underlayment Under Linoleum? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-16-2015, 07:45 AM   #1
Rewards Points: 34
Remove underlayment under linoleum?
In the middle of a kitchen remodel. As I was removing a base cabinet, I noticed what looked like a 1/4" underlayment two layers of vinyl. Is it typical to have and underlayment for linoleum? Subfloor is plywood. I plan on removing so the dining and kitchen floor are on the same level when we lay wood flooring.
untilcomplete is offline   Reply With Quote
Old 12-16-2015, 07:50 AM   #2
Rewards Points: 7,591
Linoleum properly installed is always done on underlayment to provide a really smooth, hard, void free surface.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 12-16-2015, 07:51 AM   #3
Rewards Points: 34
Alright thanks! How are they typically secured to the subfloor?
Old 12-16-2015, 07:55 AM   #4
If you are lucky a pro did it using 1/4" crown staples 6 x 6 grid. If done with UL nails you are in for a lot of cussing.
Colbyt
Old 12-16-2015, 07:56 AM   #5
Rewards Points: 34
Ha thanks I'll let you know what I find.
Old 12-16-2015, 10:40 AM   #6
Rewards Points: 18,384
And do not replace it with lauon!!
Use this instead.
http://www.homedepot.com/p/Unbranded...1178/203183010
When installing do not have the seams line up with the seams below.
Do not attach to the joist.
Do not use glue.
Once installed any gaps at the seams and any flaws need to be filled.
(no need to leave any gaps between the sheets)
Under cut any casing so the sheets slide in under it.
By far the fastest, best way to attach is as mentioned with a narrow crown staple gun.
Set in touch and go you should be able to do a whole sheet in about 2 min. and not have to go back and fill the tiny holes.
Remove old Tile adhesive before laying Underlayment? wvphysics Flooring 8 03-20-2015 02:31 PM
Underlayment for Mannington Adura LVT wwkayaker Flooring 4 01-17-2015 02:04 AM
Low slope roofing underlayment question cybergoofy Roofing/Siding 14 04-07-2014 12:38 PM
Underlayment removal around toilet donmigga83 Flooring 1 03-23-2011 10:48 PM
Removal of underlayment under toe space eyeglass Flooring 10 08-26-2009 05:59 PM
