Remove Tile From Concrete Slab, Replace W/ Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 08-30-2014, 12:12 PM   #1
Rewards Points: 31
Remove tile from concrete slab, replace w/ laminate
I have a 200sqft kitchen that I want to remove the ceramic tile and replace with 8mm floating wood laminate. I understand I'll have to chisel the tile up, question is will I need to grind the thin set smooth to lay the new floor?
If yes, any idea on a more efficient way of doing it other than a diamond grinding wheel?
I plan on a 6mil moisture barrier and a layer of padding under the laminate.
Thanks in advance for any advise
webweever is offline   Reply With Quote
Old 08-30-2014, 12:45 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A diamond grinding wheel isn't necessarily required. A floor scrubber type machine with a sanding attachment and heavy grit paper should do it. It's a dusty proposition.
XXX
Old 08-30-2014, 05:38 PM   #3
Rewards Points: 31
I popped one of the tile up in my coat closet. Turns out there is some sort of paper like backing between the tile and the concrete. It pealed right up. I've never seen that before, any idea what that is?
Definitely not the typical thinset application.
Old 08-30-2014, 06:09 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What size is the tile?
Is it mosaic tile?
XXX
Old 08-30-2014, 06:11 PM   #5
Rewards Points: 31
12x12 ceramic off white. They were put in by the builder so its pretty vanilla.
Old 08-30-2014, 06:20 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have no idea! Never seen a solid 12" tile with a paper backer except for 12" X 12" mosaic tile sheets assembled with a paper backer years ago.
XXX
Old 09-04-2014, 07:48 AM   #7
Rewards Points: 31
I've started taking up this ceramic tile, holy hell what a mess. I'm using a hammer and chisel, looking for an easier method. The hammer and chisel makes a huge mess. Is there some tool like roofers use to remove old asphalt roofing that I can use to pop these tile up?
I have a pneumatic hammer and chisel but that makes an even bigger mess.
Any ideas?
Old 09-04-2014, 11:27 AM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Any ideas?
Fun stuff - Trek on!
XXX
Old 09-04-2014, 09:29 PM   #9
Retired Moderator
Rewards Points: 7,174
It's always a dusty mess---have you taped off the doors--covered the near by rooms with plastic and tarps--put fans in the windows to remove the dust?
Old 09-04-2014, 11:00 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...covered the piano, TV's and computers, toaster, closed-off HVAC ducts?
XXX
Old 05-12-2015, 11:44 AM   #11
Rewards Points: 2
I have a concrete floor that has thin set on it I would like to put vinyl down, can I use a sander to smooth out the thin set ? if so can it be a belt sander and what grade of paper would I use,please.
sillydirl is offline   Reply With Quote
Old 05-12-2015, 12:30 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A belt sander would take forever and probably cause serious grooves that wouldn't be acceptable. A larger (side-to-side) type machine would be more suitable using about a 50 grit paper.
XXX
Does a concrete slab floor need to be level prior to tile installation? Malcolm Flooring 9 06-03-2014 10:39 PM
How to Remove Tile to replace in-floor sensor! Help! ryan5068 Tiling, ceramics, marble 6 03-26-2012 08:40 AM
Remove mastic from concrete slab CountDowne Flooring 2 11-14-2011 04:52 PM
How to tile over concrete slab with glue residue? nateo Flooring 3 04-12-2010 04:22 PM
Concrete alb preparation for Laminate (click together) flooring SJC Flooring 1 02-06-2008 03:16 PM
