Remove Subfloor Under Toe Kick - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-31-2014, 09:17 AM   #16
Rewards Points: 302
Originally Posted by firehawkmph View Post
I have a Fein tool, and it works great for many things. But in this case, the Bosch flush cut is way faster. I've cut the bottom off of 3/4" thick baseboard and gone around the whole room ( avg. size bedroom) in about ten minutes. Very nice tool.
Mike Hawkins
Would definitely be faster but is it under 3" height? Ones I have seen are way more.
JustinK is offline   Reply With Quote
Old 03-31-2014, 07:50 PM   #17
firehawkmph's Avatar
Rewards Points: 2,464
Justin,
I'll measure it tomorrow. I think it will be real close. Click on the amazon link in my post #7, it shows a picture of it. It's about the size of a Fein tool, maybe a little bit skinnier.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-31-2014, 09:28 PM   #18
Rewards Points: 1,366
Loaned my fein wanna be multi tool to someone else on a Habitat site Saturday, he comes back ten minutes later and says I guess this blade rondoesn't cut through nails. Sixteen bucks later.......!!
ront02769 is offline   Reply With Quote
Old 03-31-2014, 09:31 PM   #19
Get the Imperial brand blades with the titanium coated edge, USA made and will cut through nails. Buy em in three packs and they are cheaper than the fine blades and actually better.
Mike Hawkins
Old 04-01-2014, 07:06 AM   #20
Thanks. Mine is actually a rigid jobmax fake-Fein and I grabbed Dremel blades from HD. Most all the same price range, cheaper in the three pack granted, but still end up at around tn bucks a blade! Will have to try imperial next time.
Ron
Old 04-01-2014, 11:32 AM   #21
Ok, measured the Bosch just now. With the blade on, it's 3 5/8" tall. That being said, when I tipped or rotated the tool about twenty degrees, it's just under three inches. I think you cut this way and not cause any headaches. It would keep the blade away from the backsplash too.
Mike Hawkins
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 09:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 10:45 PM
Remove old light fixture (hanging) dj928 Electrical 9 12-02-2009 11:42 AM
How to remove Built-in Electric Fireplace Almighty Building & Construction 1 11-12-2009 05:18 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 04:12 PM
