Removal Of Felt On Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 11:39 AM   #1
removal of felt on plywood
I am renovating the kitchen and had to pull up couple layers of tile. When I got to the plywood I have a layer of what seems like a felt material that is stuck/bonded/adhered? to the plywood. It doesn't scrape away very easily. Does anyone have any experience removing a material like this? I have a feeling I will remove the 5/8 plywood and replace, but I like to work rather than spend, so if I can save the existing plywood I would be happy. Also would any carcinogen like asbestos be present in this felt like paper. My thoughts are no, cause asbestos was for wear resistance and strength?
screwy is offline   Reply With Quote
Old 12-30-2011, 12:01 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Probably the backing from a layer of sheel vinyl. Hard to say for sure without seeing it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
screwy (12-31-2011)
Old 12-30-2011, 09:29 PM   #3
Is there a chance that backing layer of vinyl would contain asbestos?
Old 12-30-2011, 09:32 PM   #4
Rewards Points: 398
Ir's possible, I suppose. The only way to be sure is to have it tested.
Adhesive window flashing and 30# felt Numb Building & Construction 4 05-24-2011 12:04 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Tar & Felt paper removal bhc65 Roofing/Siding 3 02-28-2007 04:12 PM
