Reinforcing Floor Joists Not On Edge - Flooring - DIY Chatroom Home Improvement Forum
Old 12-07-2015, 12:04 AM   #1
Rewards Points: 2
Reinforcing floor joists not on edge
I have an old house built in 1925. The floor joists are not only spaced more than 24 inches apart, they are laid on face (i.e., not on edge). Is there a way to reinforce the floor joists? Can you sister these kinds of floor joists or bridge them? I want to put down ceramic tile, but am worried the floor joists are not strong enough to hold the weight.
RogerW is offline   Reply With Quote
Old 12-07-2015, 07:38 AM   #2
ZTMAN's Avatar
Rewards Points: 492
No Way. You need to post a pic, because your floor would look like a cereal bowl if what you are saying is true
ZTMAN is offline   Reply With Quote
Old 12-07-2015, 07:40 AM   #3
Rewards Points: 125
Pics would be nice. But what I think you are saying that if it's a 2x8 then the floor is sitting in the 8" face. The weight bearing capacity of a piece of wood is a fraction of the load capacity on edge. How wavy are your floors now? In any event, the 24 inch on center probably prohibits you from ceramic tile and the current layout of the joists certainly does. I would choose another flirting material or complete rebuild this floor properly. However the joist has to sit on the sill/foundation and that is going to be an issue.
jimn01 is offline   Reply With Quote
Tags
joists , old house , tile
Install gutter apron or D style drip edge on existing roof? sophie10 Roofing/Siding 6 07-13-2015 10:04 AM
Securing fascia under the drip edge? miamicuse Roofing/Siding 6 07-23-2014 11:33 PM
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 06:04 AM
roof drip edge billygale Roofing/Siding 9 10-24-2010 03:19 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
