Refinish Or Replace Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-31-2015, 01:47 PM   #1
Rewards Points: 70
We are currently updating the inside of our home we purchased in 2010. The kitchen, dining room, entry way, half bath, and hallway leading to the laundry room have wood flooring which was installed when the home was built in 1996. The "style" at the time were wood floors that showed spacing between the boards (see photo). The kitchen floors show the most wear obviously, but the other areas could use work as well. We plan on installing wood flooring in the family room as well as the hallway leading to the bedrooms (currently have old worn Berber). My dilemma is to either try and have the wood floors refinished to have them "match", as closely as possible, the flooring we will install in the family room, or just replace all the wood floors with new. Since the current wood floors have the look of spacing between the boards, I'm wondering if the sanding during refinishing would "reduce" that look? Also, we don't plan on staying in this home beyond another 3 or 4 years so that may be a deciding factor. Any suggestions or advice would be appreciated.
Refinish or replace wood flooring-image-3904374749.jpg   Refinish or replace wood flooring-image-1551264720.jpg
scsiguru is offline   Reply With Quote
About to order wood flooring deck hand Flooring 11 02-01-2013 03:47 PM
Wood Flooring options grod777 Flooring 13 01-20-2013 05:04 PM
laminate wood flooring - after installed reds_21 Flooring 6 12-04-2009 08:22 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
