Redoing A Subfloor That Was Tiled - Flooring - DIY Chatroom Home Improvement Forum
Old 05-24-2015, 07:27 PM   #1
Rewards Points: 16
Redoing a subfloor that was tiled
I'm renovating a basement bathroom. I'm currently breaking the floor tiles. Under these tiles is a plywood subfloor that is covered with tile adhesive. See this picture: https://imgur.com/ikCX2Rl . I was considering putting vinyl tiles. However I cant lay them on an uneven surface. So what should I do? Rip the subfloor and make a new one? How would I proceed to remove this subfloor if most of the screws are filled with tile adhesive?
bighak is offline   Reply With Quote
Old 05-24-2015, 07:57 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
The plywood needs to come up. Always a bad idea to put plywood on a concrete floor. Even worse when they put ceramic tiles.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 05-24-2015, 08:06 PM   #3
Rewards Points: 16
So what kind of subfloor should I put there?
Old 05-24-2015, 08:25 PM   #4
Rewards Points: 18,382
Someone really messed up.
Tile should have been laid right over the slab. No subfloor needed.
Never ever should there have been plywood installed over the slab.
Old 05-24-2015, 08:41 PM   #5
Rewards Points: 16
I'm in Montreal, Canada. Tiling directly on the slab seems cold.
Old 05-24-2015, 09:10 PM   #6
Rewards Points: 398
It's the right way to do it.
Old 05-25-2015, 12:26 AM   #7
Tileguy
JazMan's Avatar
Rewards Points: 780
Right, and in hopes of having a more comfy floor, they did it wrong. Pry it up, fix the floor and tile on the slab. It'l feel cool the bare feet in the winter, they make slippers for that. If it's very important for the floor to feel warmer, install infloor heat mats.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Waterproofing tiled shower walls. Blondesense How To Guides 22 06-06-2014 02:29 PM
Basement Tiled shower pan drain question heinlein0311 Plumbing 3 10-26-2012 10:35 AM
Tiled Shower Repair Help, Please Unicornz0 Plumbing 2 09-16-2012 10:22 PM
Questions about caulking changes of plane in a tiled tub surround? amodoko Plumbing 2 03-18-2012 11:39 PM
Redoing tile in a exisiting tiled wet bed kpf Plumbing 0 11-28-2010 09:39 AM
