Rebar Supported Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-12-2016, 07:06 PM   #1
Rewards Points: 119
rebar supported flooring
I was remodeling my fireplace by first remove some bricks/masonry from the front piece that was on the floor. As I continued to remove the bricks, downward, I noticed that the weight of that front piece was support by rebars which were support by three columns of brick stacks. My goal is recover more floor space so I wanted to replace with regular subfloors.
Could I continue to use the bricks as flooring simply by putting a top coat of concrete to level it to the surrounding subflooring? Are the two rebars running perpendicular to the bricks sufficient to hold the flooring up? The rebars are a bout 3/4" thickness.
http://i1201.photobucket.com/albums/...fireplace3.jpg
http://i1201.photobucket.com/albums/...fireplace2.jpg
http://i1201.photobucket.com/albums/...fireplace1.jpg
suncowiam is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 09:06 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
