Reattaching Carpet To Tack Strips - Flooring - DIY Chatroom Home Improvement Forum
Old 11-23-2013, 11:49 AM   #1
Reattaching carpet to tack strips
I had to disconnect the carpet at a tile transition to fix a slab leak. I used a carpet kicker to take if off the tack strip. Now going the other way it will not grab. It appears the holes in the backing are elongated a little. I'm thinking I will have to either remove the existing tack strip to get the tacks new material to punch through or perhaps backup the existing tack strip with a second one. I didn't anticipate this being a problem. Is it possible to use carpet transition heat tape on the edge of the carpet to get new material for the tacks to penetrate?
What about carpet transition tape along the edge to give the tacks new material to bite into. I just looked at some tape that doesn't require heat but that probably isn't the best and would let go over time.
slableak is offline   Reply With Quote
Old 11-23-2013, 10:14 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
You can put tape on the back if you need it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Brand new home and sharp tack strips danandlova Flooring 25 06-13-2018 05:49 PM
Removing carpet tack strips... question. Romanova Flooring 2 07-11-2012 07:17 AM
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 05:51 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
